I use Virtual Dub for capture & it is a very good program. However, I cannot hear any sound while capturing. Under Video Source it says "ATI MediaCenter."
I heard of something called a "wrapper" in the Rage3D site. I have not problems with the sound, when played back after capture, but would like to hear it during capture, as I do using ATI Media Center. Any ideas please?
When you look at your volume settings, are any set too low?
Hello. -
Volumne is the first thing I checked. It captures in ATI MMC with sound. Then I switch to Virtual Dub-NO Sound. It's more than that.
I had the same problem. The fix is to change the sound card's "record " configuration. By default, it is usually set to "microphone". Change it to match how your capture card is connected to your sound card, usually "line in" or "aux".
RF
No Sound With Dazzle DVC100 using Virtual Dub
By kpoman in forum Capturing and VCRReplies: 3Last Post: 3rd Nov 2009, 08:35 -
Virtual dub
By santolina in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2009, 13:48 -
Virtual Dub problem
By rocka in forum EditingReplies: 3Last Post: 2nd Jan 2009, 03:46 -
help with virtual dub
By Remyisme in forum Newbie / General discussionsReplies: 7Last Post: 30th Jan 2008, 15:36 -
Some questions regarding Virtual Dub
By smackyourfupa in forum DVD RippingReplies: 3Last Post: 5th Nov 2007, 06:00
