I have tried to encode "Serendipity" from DIVX to SVCD, the source file was 23 fps, but when I burn in NERO it does not want a 23 fps mpeg file only 29 or 25 fps.
I know you can encode the 23 FPS DIVX to a 25 FPS SVCD, but then I can't add permanent subtitles.
Can anyone help me?
tlund!
23.976fps is ideal for ntsc SVCDS. If you encode in TMPGenc make sure you enable the 3:2 pulldown while playback option on the video tab to add the 3:2 pulldown flags. If you forgot or if you encoded in CCE then you can use pulldown.exe to add the flags to your mpg.
If Nero still doesnt accept it as compliant then just turn off standard compliance and burn anyways. Nero has never been a good judge of compliancy because 23.976fps with the 3:2 pulldown flag is perfectly compliant. -
Im am pretty sure that TMP defaults were 3:2 pulldown when playback, and and tried just to burn anyway, but when I saw it on my DVD player, it was not good, with all kinds of green squares all over the sceen!
Im trying again now!
But I think said that it needed either a 25 or 29 fps MPEG?
Can this be correct? -
adam's right about the 23.976 fps + 3:2 pulldown as standard for nero, it has never failed me...
but even if you turn off standard compliance, it should work...
however, i'm guessing it could be your dvd player... check the dvd player compatibility list on this website to see which formats your dvd player can handle...perhaps it can't handle non-compliant stuff..or maybe even SVCDs
also, burn at 4x max to be safe -
I have tried again now.
I have the latest version of TMP, and when I press the video buttons almost all of the options are locked (grey)! But the 3:2 pulldown when playback is default. But before I tried just to unlock where it said 3:2 pulldown when playback, and nothing more and did the rest as I am used to. I tried to put into NERO and it DIDN'T said any ERRORS or unsupported SVCD as it is used to! I burned it with a good result! Now im am encoding the whole movie! Hope it works!
But how can it be that I just had to unlock that single option and nothing else! It strange, but Im glad that it works! -
I try to burn SVCD which i convert to PAL from NTSC avi file using TMP.
Nero also complain and I click turn off but I also see green squares.
What can I do if I need PAL fomat and not NTSC
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 05:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 22:42 -
how to change fps in mp4 without reencode (maybe ps3 cannot handle 24 fps)?
By redout66 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2010, 04:53 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17
