i really been looking for a asf converter... the first tmpeg wont do it... virdub dont do it and graphix edit (or whatever it is) aint worth a shhhhhhh... can somebody please help... i dont know y somebody just dont make one....
http://www.vcdpark.nu
I use Graphedit.exe which is an asf to mpg converter... works good when you locate the correct codec -
Maybe you have already tried this but I have found that TMPGenc will work for most asf files IF you use a separate wav audio source for the audio. The only good one I know for getting the audio properly form an ASF file is using the Dbaudio converter program. This program MUST* have the plug in for WMV support that is on the page to extract the audio from an asf. Try this. I had a HELL of a time until I figured out that the program listed in the help pages needed this plug in to extract the audio from the asf. After I did use separate sources TMPGenc had NO problems. The DBaudio converter program is listed in the asf conversion section of VCDhelp.com. Good luck.
What is Better then asf tool
By Mekamur in forum Video Streaming DownloadingReplies: 2Last Post: 19th Mar 2012, 16:20 -
ASF convertor??
By yugub in forum EditingReplies: 2Last Post: 9th Jun 2011, 15:57 -
asf to vc-1
By sampalmer21 in forum Video ConversionReplies: 1Last Post: 16th Dec 2009, 14:27 -
vc-1 to asf
By sampalmer21 in forum Video ConversionReplies: 3Last Post: 10th Nov 2009, 19:47 -
AVI to asf ?
By rindless in forum Portable VideoReplies: 38Last Post: 26th Jun 2007, 09:15
