  1. i hve a couple of eppisodes of something that i wanna burn on one cd, but for some reason adaptec says that it adds the mpg's but it only burn the first one i add and none of the other ones...
  2. Thats freakin weird..never done that for me. You are in Data mode, right?
  3. no... i use vcd creator.. because i am makin a vcd... i just have more than episode that i wanna put on a disk
  4. just merge them and be done with it.
  5. unless its imperitive that you use ez-cd, i can suggest nero 5.5, it works like a champ for just this thing! built in 5 secon pause after and before the next clip is a little axcessive for my taste, so i edit that to 2 sec and 0 sec respectively.
  6. Banned
    Jun 2001
    UK
    Hi
    I use easy cd creator, with no problems. Some of my disks have now got a few intro's -
    Sounds to me your not using the wizard, its a lot easier if you use that.
    Its starts by asking for the "Simple video sequence" NEXT >
    The next screen you click the ADD button, and select the first mpeg from your drive. You can hit the Video TAB and select PAL
    And click OK
    Now click the ADD button again, and select your second mpeg file, same as above hit the Video TAB for Pal, Click OK
    Now that you have added all your mpeg files click NEXT and NEXT again
    You should now see a window on the left with both of your mpeg files in it, select them from top to bottom clicking the ADD >> to copy them over to the right hand window. NEXT > NEXT
    Create CD now.....
    "EASY" Cd creator !!
  7. thats what i did (or thought) i will try it tomorrow when i get home... thanks
