My cd-rom will not recognize that a cd has been inserted into it therefor it will not read the cd, why is that happening and how can it be fixed??
Also on each start up i am given the message cannot find NEWDOT~2.dll, what does this mean and can anyone send me the file??
Regarding your CD drive, try getting a CD Lens cleaner, it might help it, if not, check if this problem occours only through Windows, cause if it still reads CD's in DOS (Bootable CD's for example) then the problem is somewhere in Windows.
Regarding the missing DLL, have you installed anything lately ? are you by any chance located in Israel and have installed the BezeqNet CD ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Hi
Your problem is probable the brand of CD you are using, those unbranded cheep ones are not always the best. Try a TDK or Maxell, they seam to be the most reliable.
Your NEWDOTNET is regarded as "Spy wear" have you removed it recently with a program that scans for spy wear ?
The NEWDOTNET is installed by many programs, like Kaza, Audio Galaxy etc. Its function is to allow you to connect to non standard domain names.
A good registry cleaner can get rid of that for you, or try to locate the reference in your database with regedit, or even "system information" > system configuration > Startup
Hope this helps.. -
i figured out what was wrong, my cd rom and my cd rw are mixed up, the computer doesnt recognize my cd rom as being the master cd rom, instead it is the slave and my cd rw is the master, it has to be the other way around, how do i change it?
I don't see why it matters whether your cd rom is a master or slave, "once your system has recognized them".
However, there are links next to your ribbon socket marked SLV (slave) MST (Master) or something like that, you need to change those links.
And there is 2 controller sockets in your computer, if you have 1 hard drive and these 2 roms, then chances are your hard drive and cd rom is on the primary controller, but your second rom (Writer) is on the secondary controller.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
Question about BD-ROM
By II AnDo II in forum DVD & Blu-ray WritersReplies: 3Last Post: 30th Dec 2008, 18:39 -
cd-rom stripping
By marinebc11 in forum MacReplies: 4Last Post: 16th Feb 2008, 08:51 -
dvd rom discs
By johnbud in forum MediaReplies: 3Last Post: 26th Jul 2007, 06:03 -
hd-dvd rom drive
By computerchuck in forum Software PlayingReplies: 6Last Post: 8th May 2007, 07:55
