I got a movie in the theater from someones camcorder and when I play it the screens continously flashes, is there anyway to fix that its a DAT file as if it were a VCD..... ANY information would be very helpful and I thnak you
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Wait to the legit version comes out. The movie on the screen is at 24fps while video is 30.
you have a cam. Pretty much all cams are pal and I'm assuming your running this movie on an ntsc tv.
If your dvd player has a pal or multi mode then enable it and the vcd should play fine. If it doesnt all you can do is convert the mpg to ntsc. You can use vcdgear (www.vcdgear.org) to convert your dat to mpg. From there I would recommend using TMPGenc and converting to ntsc film (352x240, 23.976fps.) Ntsc is more compatible with dvd players but it would really make it unwatchable if you converted it to that since the fps is so much higher.
Honestly I would say converting it is not worth the effort since I'm sure the quality is already pretty bad since its a cammed bootleg. -
I have Freddy got fingered in AVI format (alos a theater bootleg) it works fine and all, maybe/hopfully could it be my friends computer (I don't have the files yet)....
<font size=-1>[ This Message was edited by: DeathDenied on 2001-07-03 21:48:20 ]</font> -
Im playing the files on a computer not a DVD player, I wanna (if the files turn out better) port it to VHS..
If your playing it on a pc then I have no idea, I think the movie must just be messed up. I seriously doubt there is anything you could do about it.
PC screen flashes black every 5-10 minutes - HELP!
By will7370 in forum ComputerReplies: 2Last Post: 28th Jan 2012, 18:04 -
Bedbugs now at a movie theater near you!
By aedipuss in forum Off topicReplies: 5Last Post: 14th Sep 2010, 12:48 -
Unable to view streaming URL in full screen theater mode Adobe 10
By badger1194 in forum Video Streaming DownloadingReplies: 1Last Post: 5th Aug 2010, 21:12 -
Theater recording equipment
By theaterguy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 23rd Oct 2008, 17:57 -
Making a homevideo more like a theater movie
By qazwsx16 in forum EditingReplies: 12Last Post: 4th Jun 2007, 13:56
