  1. Hello,
    I record mpg files with a satellite receiver card which is in my computer (digital video recorder).
    Some of the files are marked with a very high maximum variable bit rate. I use DVD workshop to put the files on DVD, but because of the high bit rate DVD Workshop will re-encoding the already good mpg file what I don’t want.
    When I check the bit rate with “Bitrate viewer” I don’t see this high maximum bit rate.
    My question is, is there a way to correct this maximum variable bit rate without re-encoding the file.
  2. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    First of all...I dont have a DVD burner....so I dont use the high bitrates like those who do.
    But in short...You cant change the bitrate without re-ecoding...but I dont know why DVD Workshop would reencode unless the bitrate was over say 9.8 mb/s. But the only question I ever asked here about DVD workshop concerned it not leting me do a XVCD without trying to reencode to standard VCD....Maybe this is some how related to your question???
