i got schaub lorenz vcd player.and it does not play my vcd's which i burned in my computer .how can i play them in my vcd player and if i need a software what is it?![]()
We need a little more info....Make and model of VCD player..How did you burn? What did you burn? Using what program?
You know VCD must fit a specific format, Nero and others have the option to create VCD, SVCD and others (iso, audio...) according to the coresponding standard.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
