Hi, I know I'm probably doing something wrong, but I can't figure this problem out. I used smart ripper to start with, which seemed to work just fine, Then I ran the video with dvd2avi program. Which also seemed to work fine. I then Opened TMPGE, when I try to open video file d2v it says it is unsupported. I followed the the all in one guide correctly I think. I hope someone has an answer for me. Thanks in advance.![]()
Results 1 to 1 of 1
How to add ".ass" subtitles to a ..."h264" file?
By Tatsubon in forum SubtitleReplies: 3Last Post: 20th Apr 2012, 19:35 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 02:52 -
Problem with "Application Support" folder contents (& .flv co
By Fostermeister in forum ffmpegX general discussionReplies: 2Last Post: 12th Dec 2008, 14:59 -
Staxrip: "Constant Quality" vs. "Exact File Size"
By FallenAngelII in forum Video ConversionReplies: 1Last Post: 9th Aug 2007, 18:40 -
Why do I have 2 files? "Movie Clip" and "M2V File"
By tygger in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jun 2007, 22:55
