Trying to transfer a divx.avi to vcd. No matter if i use Nero to encode and write or Tmpgenc to encode, then write with burner program there is no sound. Properties report sound as 129bit mpeg layer 3. The film plays and sounds fine on the computer. Any suggestions appreciated thx.
Does the VCD has sound on your pc???? Otherwise convert the sound from 48 khz tot 44.1 khz with virtualdub....save it as a wave file....and convert it along with the video from divx file to VCD....goodluck
i guess he the File has audio... but isn't it possible you're missing a codec?
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 14:44 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 18:01
