Results 1 to 9 of 9
  1. Hi,
    Can someone recommend a capture card that will meet my requirements?
    Basically, I want to capture some VHS tapes (mainly PAL, but 1 or 2 NTSC), so that I can write them to DVD-R. I want to try to keep the same quality as the original video tapes if possible.
    Is there a card for about £100, that would be able to do the above? Also,
    where is the best place to buy the card?
    The specs of my PC are:
    AMD Athlon 2000xp
    512mb PC 133
    80Gb IDE Hard Drive - 7200rpm
    Windows XP
    Thanks in advance for any help.
    Ben
    Apr 2002
    USA!!!
    The ATI Radeon 8500 All-In-Wonder works great 4 me!
  3. Thanks for the tip Mavrick.
    I've read some good reviews for that card, so I'll give it a go.
    Thanks,
    Ben
  4. Ive seen someone with that card and they get great results. But what can I get if I want to keep my GeForce 4 Ti4200?
    I want to make vcds, svcds, capture from vhs tapes and capture from satellite tv to make the vcds and svcds.
    Thanks.
  5. Member SHS's Avatar
    Oct 2000
    Vinita, Oklahoma
    Hauppauge WinTV-PVR 250
    Aug 2002
    England
    Avermedia Stereo
    £40/50
    Fozzee
  7. have any samples of any captures u have taken?
    Thanks.
  8. Hi
    I recommend Hauppauge WinTV-PVR series.
    AverMedia Studio(with software MPEG2 conversion) should be cost effective solution if your CPU speed is OK for waiting convertions.
    I'm using Hauppauge WinTV-PVR-pci model 883 for PAL BG. It has hardware MPEG2 encoder(also capable for MPEG1 capture), with new(and beta drivers) quality is much more then expected.
    Regards
  9. Obi. I looked at a sample of a news show and a sci fi movie captured by the AVerTV Stero card and it looks awesome!! Can I see a sample of a news show or a movie u can captures real quick with your card (like a 10 mb file or less depending on your speed). If you can that would be great. Contact me on MSN. My msn name is dreamgames@barrysworld.com
    Also my pc is a 120 GIG, Athlon XP 2200+, 512 MB, GeForce 4 Ti4200.
