I used dvd2svcd to rip monsters inc. It skipped the first vob file & ripped the rest
has any incounted this b4?
well.... i used dvd dycrypter & it ripped Monsters Inc for me just fine
Dvd dycrypter never fails for me
I had a problem with Monsters Inc and DVD2SVCD as well :
The audio went out of sync half way through the second CD.
I tried the whole process several times with the same result.
Finally, I used DVD2AVI, TmpGenc and VCDEASY to successfully create an SVCD backup of this movie.
good luck -
using 1.0.9b3 I had zero problems ripping Monsters Inc. with internal routines and no synch issues whatsoever.
Lagarith + UT codecs are HD "space" monsters !
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 13Last Post: 17th Sep 2011, 19:08 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
A ripping software that you can pick what you're ripping?
By twells22 in forum Newbie / General discussionsReplies: 4Last Post: 6th Feb 2008, 09:22 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48
