Results 1 to 9 of 9
Should I assume this to be a hacked firmware update? Pioneer has no info on it that i can find.
Hrm... ok now I also wonder want the difference is... personally I've no no issues so far with the last firmware update, but I might install this anyway to see.
I am also interested in installing the 2x unlocking and RPC1 firmware for my DVR-A04. The problem is, I already have the original 1.33 so the updater will not let me install the 1.33 hacked firmware (saying: It's already up to date ... or something). Does someone of you know of some command line switch for the update utility?
SiCN - the real one!
"Dudes, we gotta think here... What would Brian Boitano do?" -
There is a command line Upgrade but it doesn't work
I had this problem Because i had the proper pioneer 1.32 and wanted the RCE1 Firmware 1.31 i had to wait for them to bring out the RCE1 1.33
Theres no way back without doing This http://sccs.d2g.com/
Do you fancy it ?? -
Well, I don't really wanna downgrade. But how I understand it there is no way to install the same firmware version two times? I mean, it seems pretty stupid to solder around in your DVD-burner just because the DVDUPG.EXE denies installation of 1.33 RCE1?
Theres no other downgrade for your firmware other then an unoffical 1.34 hach, as for downgrading it is not in Pioneers best interest to allow that now, especially in reguards to which media companies the updates allow for use. Check out the firmware forum for all official and unofficial update. As for the 1.33 update it allow ao4 to burn on Ritec media and Cmd, which 1.32 does not allow.
http://forum.firmware-flash.com/
Pioneer DV-220V-K firmware version?
By batyar55 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 20th Jun 2010, 14:27 -
Pioneer DVR-216 and Firmware
By dqtus in forum DVD & Blu-ray WritersReplies: 5Last Post: 27th Mar 2009, 03:26 -
Pioneer DVR-K17RS Firmware wanted
By snadge in forum DVD & Blu-ray WritersReplies: 3Last Post: 17th Dec 2008, 19:45 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-115D Firmware Upgrade
By G13 in forum MacReplies: 3Last Post: 23rd Apr 2008, 02:14
