Results 1 to 10 of 10
    Feb 2002
    newfoundland
    hi i just have a quick problem with tmpeg, i use smart ripper to ripp my dvd then i use dvd2avi to ripp the audio of it, when i go to put the .d2v file in as the video output in temp, it wont let me says file is not supported or somthing, the audio will go in fine, but the video won't ? , im using tmeg 2.58 , and i have never had this problem b4 wit hit, anybody know what im doing wrong etc.....
    and help would be greatful
    steve.
    p.s. how do i ripp a dvd , into jus .avi. i dont really care about mpeg and vcd ,....would i still use tmepg and dvd2avi , and if so what would i do with the .d2v file to make it avi.....
    hehe thanks if anybody could answer those 2 questions.....
    Feb 2002
    newfoundland
    hmmm im still having this problem , tried other dvd's now, does tmpeg not support .d2v files anymore.???? ...........
  3. Member MaDmiZe's Avatar
    May 2002
    City of...Atlanta
    You are saying that it will not accept the d2v file as the video in right.
    Did you recently change versions or reinstall TMPG ?
    If not you may want to go into TMPG environmental settings (under options) goto the goto the VFAPI tab and right click on DVD2avi project reader and click on higher priority a couple times...so its at least a 0 or a 1.
    For the AVI part TMPG will do avi also....set up like normal....but instaed of clicking start....goto file>output to file>then avi. I think DVD2AVI also has the option to say AVI.
    Feb 2002
    newfoundland
    yeah i just treid chaning the dvd2avi option in env. settings in tmpeg, but it says it wont read it....im trying dvdx now a differnt program, but i found taht my cpu got stuck when i tried .................very weird my cpu is like ******* up or something...................
  5. Yo first of all your missing the right components you dont encode using *d2v's they suck as frame serving the best way to do it is with VFAPICodec but you'll also need the plugins for TMPGEnc 2.58 get them @ www.tmpgenc.net get the TMPGEnc_Free_VFAPI.zip and download the VFAPICodec then get back to me on instructions.
    Feb 2002
    newfoundland
    hi ihav downloaded and installed both things u told me to to do, .......now all i need to know is how to use them....
    Dec 2001
    USA
    Unzip the file into the dir where tmpgenc is, then run the install bat file this will install it.
    May the force be with you.
    Feb 2002
    newfoundland
    hi that last 2 dvd's that i have rippedn now i have just used , smart ripper then used dvdx as teh program to make it into mpeg, is there any problem in doing this, is it the same quality as using tmpeg....i seem not to have any problem using dvdx .......
    thanks
    steve.
  9. Originally Posted by bigred3
    actually, the feeling around here seems to be that dvdx is not that good in terms of quality.... the all-in-one proggie of choice seems to be dvd2svcd..
    i personally still like to use separate programs because it gives more flexibility, but if you want something easy to use, then i suggest using dvd2svcd, rather than dvdx
    Feb 2002
    newfoundland
    hehehe i dont have a sweet clue how to use dvd2svcd or whatever.......all them frigging boxes....im trying dvdx again now wit the dvd rules of engagment just to see how it looks if im not satisfied with the quality then i will have to go with the program u where talking about...
