  1. i tried ripping a dvd with eazyvcd i think its called and i put it give the best quality possible, only thing is the quality still wasnt as great as a wanted. I have a dvd burner so a dont really mind that big of files. I just want to be able to fit 2 movies on one cd if possible. I downloaded some real good dvd rips and i was wondering what kind of programs and settings you all could recommend to achieve this.
    Apr 2002
    Ireland
    2 movies on 1 cd? that's possible, but the picture qaulity would be crap. if you want to put 2 movies on 1 disc get a dvd burner. you will be able to then put 2 movies on 1 dvd-r with reasonable qaulity.
    jma has a dvd burner and want to burn on cd? or do you mean burn dvdr? it is confusing...
