Here is my situation, I was making a vcd/cdda combination. First I made the VCD structure, then I added some additional directories to it and burned it to CDRW. What I was going to do from here is rip the image off to bin/cue using CDRWIN, then burn it back to a CDR with some audio tracks using Baldricks guide. However, CDRWIN is detecting an illegal track and wont rip the vcd to an image file. I can only suspect it is the extra directories causing problems. Is there anyway I can get around this and burn a bin/cue or some other program that does it, or can I rip the image using another program and convert to bin/cue?
tygrus
Results 1 to 1 of 1
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
