I have noticed that in TMPGEnc it has under the file menu "Save Project" does this mean that in the middle of encoding I can save the movie I am encoding and go back to it later? because my computer keeps freezing while trying to encode.
Save project will save the settings you have set up for the file (segment, filters, bit rate etc..) but if you stop the encoding then you'll have to restart from the beginning.
While you can suspend a TMPGenc and then continue it latter (I use to do this), save project is more for batch encoding. You can set up several encodes, save each one (make sure you give them different output names) and then choose batch encode, add the saved projects, hit run, and take a (long) nap
Pretty nice if you want to encode several short clips and/or multiple movies while at work.
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
TMPGEnc to License x264 Encoder for TMPGEnc 4.0 XPress
By poisondeathray in forum Latest Video NewsReplies: 17Last Post: 28th Jan 2011, 16:07 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 14:23 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
