Hey VCD gurus,
Okay, just d/led a movie but it was only a .bin and no .cue.
What do I do?
I checked and there is no .cue that i an d/l.
I use Nero, BTW.
Thanks for the help...
Start NERO, goto File/BURN IMAGE, in the next window select all files from the FILES OF TYPE, then load your bin.
In The Next window you either got to select Data Mode 1 or Data Mode 2,
also change the block size to 2352 in you choose Data Mode 1.
I would suggest that you burn the bin onto a CD-RW first to see which option works, then go back and burn it proper to CDR. -
You will have to "regenerate" the CUE/BIN image.
I don't recommend burning the BIN without the CUEsheet.
http://www.vcdhelp.com/forum/viewtopic.php?t=117271&highlight=regenerate
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
