I have an .avi that is more or less like most
downloaded 695 MB. However, this movie
lasts 1 hour 48 min. (longer than the ones
found thus far). Now when I extract the Audio
with VirtualDub I get a huge audio file 1.1 gig.
Isn't this rather strange as it generally is the
almost same size as .avi file?
Can I reduce this audio file because I am sure
my final converted VCD will now not fit
on 1 CD.
Thanks!
load the wav file you created into tmpgenc along with the video file .. for a vcd the wav is compressed to a mpeg1 audio file layer 2 and will be very small.
you didnt really need to extract the wav anyway .. -
44,1k stereo = 10mb/minute uncompressed
1:48 = 108 minutes * 10 = ~1.08gb
So yes, that is correct.
MP4 audio extraction (ripping the 5.1)?
By takearushfan in forum AudioReplies: 15Last Post: 13th Sep 2010, 08:12 -
Audio extraction from DVD using VirtualDubMod
By Ogilvy in forum AudioReplies: 4Last Post: 29th Mar 2010, 15:56 -
MP4 Audio Extraction
By neumannu47 in forum Video ConversionReplies: 2Last Post: 28th Aug 2008, 19:17 -
5.1 audio channel extraction
By efiste2 in forum AudioReplies: 3Last Post: 15th Sep 2007, 04:05
