  1. hi all, i have got a vcd in .tar format and have tried winzip winrar isobuster etc and get all the files extracted eg 28 tracks but cannot burn it ive never come across this format b 4 and ive done a search and nothing exists abut it as far as i know. any help on how i can watch this and burn it would b appreciated.
    thanx
    stu252
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    tar is just a compression format .. in what format are the EXTRACTED files in ? thatis what is importaint to know to determin what you will need to do with them ..
    also make sure you can play the extracted tracks - because if you cant you will need to prob install a codec also ..
  3. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    Shot in the dark here.
    Are you sure its a vcd?
    Based on the number of tracks its sounds like someone compressed an audio CD to a TAR format.
    What is the extension on the extracted files?
    Now that the tracks are uncompressed see if you can play them.
    There's not much to do but then I can't do much anyway.
  4. Renegade gll99's Avatar
    May 2002
    Canadian Tundra
    PS
    If you do a Google search on "TAR Compression" you will find sufficient material that explains its origins and use.
  5. thanx for the help guys ill try some of your ideas.
    stu252
