  1. I bought some cartoon series VCDs from an online auction. One series wasn't done correctly. 10 disks, 3 'toons per disk. Disk 1 has audio on the first cartoon, but not on the 2nd or 3rd. Disks 2-10 have no audio at all. When I copied them onto my computer and played with the Windows Media Player, they were okay though, sound and all. If there is sound on the computer, shouldn't I be able to get that onto the disk somehow also?
    I don't know what I'm doing, but I figured *maybe* if I converted one back to MPG, then made a new VCD disk from that, maybe it would come out correctly, like it just somehow didn't convert correctly when first made. Nope, still no audio.
    Help?
  2. Anyone? I've looked for similar posts, but none that I can tell are quite the same.
