    Oct 2002
    new york
    I am fairly new to this but I can not seem to get my svcds to look really good they all seem to look very pixelated. I am using movies that I download. Even if they look good on my pc they just don't seem look as good on my TV. Is there a setting in tmpegnc that will give me the best outcome?
  2. yeah, i guess if you do EXACTLY as they say HERE you'll get a good quality...
    Sep 2001
    N/A
    heck your resouloution on the file.
    If the file is above 480x480 then use CCE to convert to a svcd at 2500cbr.
    If below 480x480 then use tmpegenc to convert to vcd.
    Baker
    My vcd & cvdGuide
