Results 1 to 13 of 13
    Oct 2002
    Rochester, NY
    so i take it that an avi movie encoding it to a mpeg svcd will not compress it smaller to fit onto on CdR? exp 560mb avi covert to a 770mb MPEG now i have to go buy DVD-R which hold upto 4gb
  2. Member Treebeard's Avatar
    Aug 2002
    If your mpeg file is less than 800mb and your burning it as a vcd or svcd then it will fit on an 80min cd.
    in the (S)VCD mode of burning; 800mb will fit on 700mb disc because its burning in mode 2
    Oct 2002
    Rochester, NY
    SLOB
    well when i did convert with Nero, it's telling me it needs a bigger CDR to fit the 776mb movie on the cd and im using 700mb cd, so it won't burn it, keeps spitting the cdr out, i hate to cancel the job then i would have to start encoding all over again
    HELP
    this sucks
  4. Member Treebeard's Avatar
    Aug 2002
    you need to go setup nero to allow overburn- set for 82min. You also have to have the disc at once box checked.
    Oct 2002
    Rochester, NY
    will i loose the current encoding? sounds like i might have to start over. then i can save it change my settings on nero like you said and i hope for the best
    "the big rigatoni"
  6. Member Treebeard's Avatar
    Aug 2002
    are you using nero to do the encoding? If you are you wont get the best results. i suggest using some other software to encode your movie. the results will be much better.
    Oct 2002
    Rochester, NY
    yes i am, can you tell me your best recommendation for an encoder? then i will use Nero to burn it according your specs also can i get your email if i have more q&a? plus is have old pc which take forever to encode
  8. Member Treebeard's Avatar
    Aug 2002
    im assuming your avi is a divx file correct? Here is a guide that will walk you through taking an divx file and making it an SVCD and then you can burn your SVCD to a cd. With the quality of the encoding you will probably need to put it on 2 cd's.
    http://www.vcdhelp.com/tmpgencsvcd.htm
    take it step by step and all should work
    Oct 2002
    Rochester, NY
    yes you are correct again divx, ok i can still use nero to burn on two cd? sounds like to have to split the movie, according the link you sent me anything over 60 min svcd might have to cut, or i will just get DVD-Rs which hold 4gb of space
  10. Member Treebeard's Avatar
    Aug 2002
    yes you can still use nero. following that guide you will end up with 2 files. in nero just select SVCD and burn each file to a disc.
    ps encoding will take some time but well worth it.
    Oct 2002
    Rochester, NY
    so im better off getting DVD-Rs every use them? well if im right you don't need a dvd burner, you can use them to burn bigger mpeg onto the cd
  12. Member Treebeard's Avatar
    Aug 2002
    If you want to. I have never used them because i dont have a dvd burner.
    So i cant help you with any dvd burning issues
