Hi to everybody.
I hope someone can help me.
My questions are:
1) Which are the differences between various DVD media discs.
2) which is the best dvd recorder to copy dvd movie
3) how can i copy a dvd movie dual layer to one dvd without reencoding the movie, without 24 hours reeconding
4) dvd 9 gb exists
Thank you everyone who can help me.
Thanks a lot
tex78
8)
2. dvd-rw/dvd+rw combo dvd writers
3. You cant...well you can split it to two dvdrs or use double sided dvdrs
4. Only double side 9gbs exist which mean that you must flip them. Dual layers dvdrs (9GB) and dual layer writers does not exist. -
thank you Baldrick for answers you tell me, but i don't understand one thing.
Answer n° 3 you tell me that i can't copy a dvd 9 into a single dvd, or that i can copy in a double side dvd, but in answer number 4 you tell me that dvd 9 double side doesn't exist.
I don'understand what you have said to me.
Can you help me and specify the carachteristics of Dvd discs?
How many types there are, capabilities, for which player are made, and for which type of usage are made.
Thanks al lot
Tex78
forgot to add exist to point 4.
Note that double side and dual layer are different, double side means that it is 4.7GB on each side of the dvd(you must flip the disc) and dual layer is two 4.7GB layers.¨
More dvd disc types info here
http://www.dvddemystified.com/dvdfaq.html#3.3 -
How many type of media discs there are?
DVD r
DVD RW
DVD RAM
DVD ROM
you can tell me the specification of alla discs plese !!!!
and which i must use to copy dvd's
and which are double side
thanks
texThe world is in your hand! -
dvd-r/w and dvd+r/w are the main dvd writing formats and new dvd writers support both so you dont have to choose and both support double side dvdrs(not DUAL).
dvd-ram is not supported by most standalone dvd players so it is not that useful.
dvd-rom is a computer dvd drive.
very basic info www.vcdhelp.com/dvd
more detailed info www.anandtech.com/guides/viewfaq.html?i=118 -
well he is wrong in one standard, DVD-Ram is very useful, specially if you use a standalone DVD Recorder then they beat the pants off a DVD RW, since you can't edit on a DVD RW like you can a DVD-Ram, A RAm disc acts just like a large hard drive you can erase, re-arange and play and record the same time on them, you can not do this with a DVD RW.
Its really ausome when I am recording a 2 hour race and come in one hour into the recording and hit play and start watching the begining of the race while it still goes ahead and records the rest of the race and you can pause, search and stop while playing and no effect the recording thats going on, yeah try that with a DVD RW, NOT!!
I have not problem finding panasonic standalones and DVD Rom drives by toshiba and panasonic that supports Ram, granted it way limited, but where else can you get a 4.7 gig portable hard drive for $8, yes all I pay for the Rams are $8 and tranfer data back and forth from computers. -
This thread is quite old, but it is interesting to see that DVD-RAM was around in 2002. (Although I had read that it was presented in 1996 by the DVD Forum.) The laptop computer I have (purchased in August 2007) is capable of writing to DVD-RAM. I read somewhere that gave the general comparison between DVD-/+RW and DVD-RAM was that the RW have a cycle life of about 1000 rewriting compared to 100,000 for RAM. And another advantage of DVD-RAM discs is that of long durability estimated at a minimum of 30 years. I also remember that it had a significant technical difference from other types DVD media in that it was physically more like magnetic drive media that used concentric tracks instead of a spiral.
We are All ONE!
Home video 8.4GB on Dual Layer DVDr want to put on 2 4.7gb dvdr ??
By rockonvidtrade in forum Authoring (DVD)Replies: 11Last Post: 19th Oct 2013, 23:25 -
DVD to AVI/DVDR and AVI/WMV/MOV to DVDR
By BIFFtheSTIFF in forum MacReplies: 5Last Post: 19th Nov 2010, 12:35 -
What device will enable recording of TV to DVDR and DVD or VHS to DVDR?
By enricomad in forum DVD RippingReplies: 1Last Post: 26th Jun 2008, 17:46 -
PAL DVDR to NTSC DVDR including menus + extras? Is there an easy way?
By junkmonk in forum Video ConversionReplies: 3Last Post: 13th Mar 2008, 23:19 -
Apple Trailers to HD-DVD or BluRay on a standard DVDR/DVDR-DL
By Scooter_NJ in forum Video ConversionReplies: 0Last Post: 21st Feb 2008, 18:14
