hi - could anybody give me a tip on how i can add a vcd menu to a VCD that i usually burn using a downloaded MPEG file ?
many thanks
marc
You may find some tips here, http://www.vcdhelp.com/author#menu
maybe not mac guides...i didnt check what forum I was in.
thanks baldrick - but i use a mac and unfortunately there is no tips regarding a way to do it on a mac - at least i did not see any. but thanks anyway
Look here http://homepage.mac.com/rnc/MMGen.html, see if it helps you.
tgpo - thanks alot ! now i have one problem left - how do i create an .mpg file that i can use as a menu ? there is no help text available for missingmenugen - i tried to take a .jpg and turn it into an mpg using quicktime - but i am not sure if this will work - can anybody help ?
Try using VCD Builder. I use it for my VCD authoring and menus work great. At one point I had a XVCD authored using TMPGEnc (to convert the framerate up to 29.97 properly) and then spliced/authored under OS X (3 Anime fansubs, cut off the openings/endings and placed them at the begining/end of the VCD, with the menu leading into the episodes themselves).
The VCD worked rather well. VCD Builder can convert images into a menu for you too.Slaughtering the competition with amatuer-quality VCD authoring abilities... fear my non-l33t skillz. -
tk265 Sorry I left the docs out in the last upload. This is fixed now, please download again. If you have questions you can emai me direct.
RNC
Is it possible to add a DVD Menu to a AVI?
By Rayster in forum Newbie / General discussionsReplies: 9Last Post: 7th Aug 2010, 11:47 -
add menu without re-encoding
By mathmax in forum DVD RippingReplies: 2Last Post: 9th Jul 2010, 11:40 -
Add a language menu to a DVD
By hellbound in forum EditingReplies: 0Last Post: 6th Aug 2008, 11:01 -
Add subtitle, keep menu/extras
By canaQ in forum Authoring (DVD)Replies: 3Last Post: 4th Jul 2008, 06:36 -
Add menu to existing DVD?
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 2nd May 2008, 18:56
