I have a final .MPG synced output from ffMpeg 0.0.4d that I need to split into 2 .MPG files. I am using MpegPowertools to do it. After I get my 2 chuncks I use VcdToolsX to make the .XML file and hopefully the IMG files.
My problem is that chunk 1 works great. But when I use VCDToolsX to try and make the IMG files for chunk 2 it doesn't work. I get a real short burst on the barbar shop twister and then it is over. I get a .TOC file and nothing else.
What is different about the second chunk that this is happening ?
-Squeed
are you selecting save headers when you split the files? give me the exact process your doing and maybe i can help... but currently i dont have enough info to go on.
Splitting up a video?
By bartman99 in forum MacReplies: 3Last Post: 27th May 2010, 08:13 -
Help with splitting
By stinger161 in forum EditingReplies: 1Last Post: 29th Oct 2009, 17:58 -
Help! Splitting a DVD
By StrikerZERO in forum Newbie / General discussionsReplies: 2Last Post: 17th Sep 2008, 19:19 -
Video Splitting?
By xcape in forum EditingReplies: 3Last Post: 10th Jul 2007, 18:06 -
cutting and splitting
By ichigo15 in forum EditingReplies: 1Last Post: 18th Jun 2007, 20:01
