Hi Guys,
I'm trying which I believe is a simple task of converting DiVX 3 to DVD so I can burn it to DVD-RW. I converted the audio using VirtualDub then use TMPGEnc to convert the video and audio to a merge DVD format. However I found the sound to go out of sync with in the finished format when played back.
Can any point me in the right direction as to what went wrong?
Thanks in advance,
Andy. 8)
Results 1 to 1 of 1
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 10:31 -
Problem with A/V sync....but not before.
By kcsport in forum Portable VideoReplies: 0Last Post: 21st Feb 2008, 18:53 -
a/v out of the sync problem...
By drstupid in forum Newbie / General discussionsReplies: 6Last Post: 12th Jan 2008, 01:27 -
sync problem
By Madgelina in forum SubtitleReplies: 3Last Post: 1st Aug 2007, 14:29
