  1. hi
    well, i have tried to encode with CCE cause everyone says its so damn good, :P , but when i encoded a little bit, cancheled to see the quality, damn, it was like 4x forward
    anyone know what it can be ??
    and, can i change the resolution on CCE, for example if i want 352x240 ??
    GG smurf
  2. Member adam's Avatar
    Sep 2000
    What does 4x forward mean? Do you mean playing really fast? This is often what happens when you play a video stream by itself in media player. Let the encode finish and multiplex it with your audio then view it in a software dvd player to test quality. There is also a great avisynth filter called MonitorFilter which creates a preview window while CCE encodes so you can see the quality.
    The only resolution changes CCE supports are half vertical and half horizontal, so actually if you had a 720x480 source I think you could resize it to 352x240 in CCE by checking these tabs, but I'm not so sure how good CCE resises.. To adjust your resolution you need to do this through frameserving. You really need to read a guide on CCE, and the manual as well. Its not an intuitive program like TMPGEnc.
