Has anyone sucessfully copied a VCD via command line?
I tried cdrecord -v dev=1,3,0 speed=16 -isosize /dev/scd0
It seemed to work. Here is the output:
Cdrecord 1.11a31 (i586-mandrake-linux-gnu) Copyright (C) 1995-2002 Jörg Schilling
TOC Type: 1 = CD-ROM
scsidev: '1,3,0'
scsibus: 1 target: 3 lun: 0
Linux sg driver version: 3.1.22
Using libscg version 'schily-0.6'
atapi: 0
Device type : Removable CD-ROM
Version : 2
Response Format: 2
Capabilities : SYNC
Vendor_info : 'YAMAHA '
Identifikation : 'CRW2100S '
Revision : '1.0H'
Device seems to be: Generic mmc CD-RW.
Using generic SCSI-3/mmc CD-R driver (mmc_cdr).
Driver flags : SWABAUDIO
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R96R
Drive buf size : 7582848 = 7405 KB
FIFO size : 4194304 = 4096 KB
Track 01: data 570 MB padsize: 30 KB
Total size: 654 MB (64:53.32) = 291999 sectors
Lout start: 655 MB (64:55/24) = 291999 sectors
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 4
Is not unrestricted
Is not erasable
Disk sub type: Medium Type A, low Beta category (A-) (2)
ATIP start of lead in: -12508 (97:15/17)
ATIP start of lead out: 359848 (79:59/73)
Disk type: Short strategy type (Phthalocyanine or similar)
Manuf. index: 22
Manufacturer: Ritek Co.
Blocks total: 359848 Blocks current: 359848 Blocks remaining: 67849
Starting to write CD/DVD at speed 16 in real TAO mode for single session.
Last chance to quit, starting real write in 0 seconds. Operation starts.
Waiting for reader process to fill input buffer ... input buffer ready.
Performing OPC...
Starting new track at sector: 0
Track 01: 570 of 570 MB written (fifo 100%) 16.1x.
Track 01: writing 30 KB of pad data.
Track 01: Total bytes read/written: 597979136/598009856 (291997 sectors).
Writing time: 277.199s
Fixating...
Fixating time: 23.287s
cdrecord: fifo had 9419 puts and 9419 gets.
cdrecord: fifo was 12 times empty and 8012 times full, min fill was 0%.
and if i diff the two VCD's I get:
diff /mnt/cdrom /mnt/cdrom2
Common subdirectories: /mnt/cdrom/cdda and /mnt/cdrom2/cdda
Common subdirectories: /mnt/cdrom/cdi and /mnt/cdrom2/cdi
Common subdirectories: /mnt/cdrom/ext and /mnt/cdrom2/ext
Common subdirectories: /mnt/cdrom/karaoke and /mnt/cdrom2/karaoke
Common subdirectories: /mnt/cdrom/mpegav and /mnt/cdrom2/mpegav
Common subdirectories: /mnt/cdrom/segment and /mnt/cdrom2/segment
Common subdirectories: /mnt/cdrom/vcd and /mnt/cdrom2/vcd
Everything seems copisetic, however the created VCD cannot be played in mplayer, ati vcd player, or my set top box DVD player. The original VCD will play in all of them though.
Can anyone tell me where I went wrong?
Can anyone give me an alternitive that works via the command line?
I don't use Linux much at all, but it seems to me that you basically copied the "VCD" as if it were a CD-ROM. That is, simply copied the "filesystem" to a new disc.
This is not a VCD and it won't work...
Regards.Michael Tam
w: Morsels of Evidence -
OK, now I know where I went wrong.
Can anyone give me an alternitive command structure to make this come out right? Suggestion on alternitive apps to make a proper VCD via commandline? -
Off the top of my head I don't remember the arguments, but you need to use cdrdao to copy. cdrecord doesn't do DAO burning.
I "think", that you could probably get away with that old classic, dd, to make an image of the vcd, then just use cdrecord to burn it.
Something like:
dd if=/dev/[whatever] of=vcd.img
where /dev/[whatever] is your CDROM device.
This will hopefully create an image of the vcd called vcd.img, in the current working directory.
How to Use x264 Command Line
By Anonymous344 in forum Newbie / General discussionsReplies: 37Last Post: 2nd Nov 2013, 09:49 -
About cdex command line
By kathir. in forum DVD RippingReplies: 0Last Post: 21st Jul 2011, 03:25 -
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 03:23 -
High-Resolution VCD/SVCD Stills on the UNIX Command Line
By sterno in forum User guidesReplies: 7Last Post: 20th May 2009, 13:16 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 2nd Jun 2008, 00:44
