almost every video file i download now is almost out of sync in divx...i have nimo codec pack and all, what could be wrong?
Results 1 to 9 of 9
Do you have anuff RAM? i know i have 64mb of RAM in my 600mhz PC across the room and it skips and is out of sync on every divx i have.
Keep your system as clean as possible - codec-wise
Many may dissagree but things will go all right if you have just one version of a codec installed
IE don't install 4 diffrent AC3 filters and 3 diffrent MPG2 filters and such
as for divx me thinks the good old div3 and the latest div5 should bee all you need. -
most likely your audio is recorded with a variable bitrate. you will need to convert this to a constant bitrate audio source. one way to do this is to use virtual dub
i have enough ram 256 and 128 on the other. i have nimo and the normal divx but it was out of sync when i only had one thats why i got another. its fucked up, i downloaded3 more just to test tonight NONE of them are in sync i even formatted and the hting is they used to work! odd as f*ck.
get rid of all your codecs, then reinstall just what you need.
now, i cant watch .avi files at all on my pc. even divx player crashes. I cant use WMPlayer for .mpgs, I have to use PowerDVD and they often lock my machine.
Too many screwed up codecs.
however, as long as the audio is ALWAYS constantly out of sync, it's easy to repair. Look in the guide section. It's not a big job. -
Well it seems to be in sync some times and not at others. Weird? I didn't have any codecs install then I installed one and it was still like that.
Try uninstalling the nimo codec pack...and only install the codecs u need (eg Divx 5.0). Keep in mind it might not be the codec, there are a lot of screwed up divx files around..
Also look if there aren't any programs like spyware on your pc...if so..remove them (eg. Ad-awere)
If all fails....and U really want it to get it right at all price.....format your harddrive and reinstall windows... it sometimes helps...
Kinda n00b with ripping - kids ruining DVDs!
By pizzaguy4hire in forum DVD RippingReplies: 7Last Post: 11th Jan 2012, 21:58 -
HUGE Ripping Problem...HELP
By mgbatman in forum DVD RippingReplies: 9Last Post: 27th Nov 2010, 02:41 -
JVC GY-HM100 has a huge problem !
By Turmap in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 15th Apr 2010, 13:31 -
Problem that I have been trying to solve for three days. as of nov.28th
By jaredc91 in forum Software PlayingReplies: 6Last Post: 29th Nov 2008, 00:25 -
Body Glove Case ruining DVDs?
By jwnulife in forum MediaReplies: 6Last Post: 10th Feb 2008, 20:21
