i ripped the dvd with smartripper, then i used dvd2avi. i have the d2v file, but there is no wav. file to use in TMPGEnc. i have that are unknown and i think these were supposed to be the wav. file. what can i do?
How did you rip with smartripper? Did you check Track number when save project with DVD2avi. Make sure the track you check not DTS you can check after save project on small screen display. It should be like "DD 3/2" "DD 2/0" if it show DTS then you will not have wave file.
try cladDVD XP, and let it frameserve, select the audio track you want. it will give you the d2v file plus the .wav file you need. I found this software easier to use.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
New here - Quick questions
By ImportGuyR34 in forum Authoring (DVD)Replies: 6Last Post: 10th Mar 2011, 07:11 -
Need some quick help with IMGBurn
By flyin-lowe in forum Authoring (DVD)Replies: 4Last Post: 8th Dec 2010, 19:20 -
Quick Hello :)
By Paul Iddon in forum Newbie / General discussionsReplies: 1Last Post: 17th Feb 2010, 17:14 -
Aften - Is it really that quick?
By 44echo in forum AudioReplies: 20Last Post: 30th Dec 2009, 22:04
