I'm using dvd2avi to rip my audio but I've noticed the last few movies have had audio files about 1.2 gigs!, thus making me having to lower my average bitrate settings in CCE, maybe this is normal? all the other movie audio files I've worked with in the past have been pretty much all under 500 megs!.
Also noticed that when I drag the audio file over into senarist I'm prompted with "What kind of Oject do you want to create from Pan AC3 T01 2_0ch 192Kbps 48Khz" giving me two options to choose from MPEG1 or PCM Audio and AC-3 Audio, I have been selecting the AC3-Audio, is this right ??
Any ideas?
I thought of recoding the audio but I'm not keen cos I'm all for cystal clear sound quality.
you are for some reason extracting raw pcm data instead of the ac3 file ..
I agree with BJ_M, but I'll tell you how to fix it.
Click on Audio in the toolbar and select Channel Format. Make sure that Auto Select has a check mark by it by clicking on it. Most likely you have selected Linear PCM.
This happened to me and that is how I fixed. I hope this helps.
Good Luck.... -
Me again being a dumb shit, sorted now.
My audio is now 199Megs.
thats twice I've posted uneccessary posts
sorry
Copying a large MP3 audio file to 2nd CD-R once 1st CD-R is at capacity
By keypoints1 in forum MediaReplies: 10Last Post: 20th May 2011, 23:44 -
Help with large TS file
By mejallen in forum Newbie / General discussionsReplies: 1Last Post: 23rd Mar 2010, 20:44 -
large iso file
By fabpozzi in forum Authoring (DVD)Replies: 10Last Post: 13th Dec 2008, 13:10 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
Large .dvr-ms file?
By ukcat in forum Newbie / General discussionsReplies: 2Last Post: 7th Sep 2007, 16:47
