How to put 2 stereo channels on a SVCD ?
Author your video and two audio streams separately. Multiplex all three together either in bbmpeg, I-Author, or TMPGEnc using its simple multiplex option in mpeg tools.
Originally Posted by adam
But... When playing that CD at home, only one of the sound files can be heard. When I press the äudio button of my Philips 623, it says :
Audio 1/4 MPEG2 4CH ... something like that. So on 1/4 and 2/4 I hear the first sound file (in fact a little bit different, maybe those are its left and right channels). On 3/4 and 4/4 it's just silence.
Any suggestions ?Best wishes,
UP -
My suggestion is to use bbmpeg. TMPGenc has problems in general with multiplexing mpeg2. You can find a link to bbmpeg in the tools section and a guide on how to use it in the EDIT section, its the cutting guide but just ignore the cutting part and it tells you everything you need to know.
My suggestion is to always use bbmpeg for multiplexing mpeg2 regardless of how many audio tracks you are using. -
It seems more that your player assumes 4 mono channels instead of 2 stereo. Maybe there is a setting on the player?
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
How to reverse stereo channels for a moive file?
By paytonlow in forum AudioReplies: 7Last Post: 18th Sep 2010, 11:31 -
Stereo, Joint Stereo or Dual Channel for Audio input type?
By c627627 in forum Capturing and VCRReplies: 1Last Post: 23rd Mar 2009, 09:33 -
In the future, how many sub-channels could be put into one 6-mhz space?
By Frank-0-Video in forum DVB / IPTVReplies: 13Last Post: 31st Jan 2009, 00:36 -
Removing one of the Stereo channels In Premiere Pro 2.0
By HarveyCee in forum EditingReplies: 7Last Post: 21st Oct 2007, 14:18
