I've done a few rips an i've never had the problem of tmpgenc not being able to read my DVD2AVI audio files.Can someone help me it locates the video fine but not the audio,maybe i've changed some i'm not sure.Thanks
Maybe you selected a DTS audio track?
I do not think dvd2avi can decode DTS. -
do you mean dvd2avi didn't create the audio wav file?Originally Posted by oly19
or do you mean dvd2avi did create the audio wav file, but you can't load it into tmpgenc? -
can you play the audio wav file on media player?Originally Posted by oly19
what's the filesize of the wav file? -
yes they play.one of them is an AC3 T01 3 2ch 448bps the other is T02 2 0ch 192kbs.I noticed all my rip sound usually are in music match files now they are in windows media an wont load.when they where in musicmatch file set i had no problems.Thanks oh the first file is 572mb an the 2nd is 244mb.
how to RIP/COPY dvd with bad sector??
By ysfm in forum DVD RippingReplies: 5Last Post: 25th Feb 2011, 01:00 -
Can a Anydvd rip actually be bad and cause skipping?
By AndyD in forum Blu-ray RippingReplies: 4Last Post: 11th Apr 2010, 21:38 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
Bad Sectors on Rip from DVD
By AlfB in forum Video ConversionReplies: 6Last Post: 5th Jan 2009, 21:02 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 20:45
