Hello all,
i have a movie as a ".avi" file which plays good on the computer with sound and video over the Windows Media Player version 9 beta.The thing is when i try to convert the avi file to a VCD or SVCD (mpeg format) for what im using TMPGEnc version 2.53.35.130 i only have the video track but no audio track so after the converting i only have the video but no sound on the movie.Also i tryed to get the audio file with Virtual Dub Beta 2.2 so i can mux all together with TMPGEnc which doesnt work either because Virtual Dub is not able to read the ".avi" file which i want to convert.Now i dont know what to do to get the avi file converted to a useable mpeg foramt![]()
I have Divx 5.02 ,i have the Nemo Codec Pack the Movie is playing with Windows Media Player so i hope now maybe one of u guys have a good idea what it could be and what i should do to get this done![]()
Alrighty take care guys
Andi
Have fun with mpge,avi,svcd,vcd and so on....
What happens when you try to load the file into VDub?
Hello. -
What is Virtual Dub Beta 2.2 ???
There's not much to do but then I can't do much anyway. -
Hi again,
when i load the file into Virtual Dub it works but then when i try to save the audiotrack as wave file this message appears:" The requested audio compression is not compatible with the input format.Check that the sampling rate and channel count of the input match those of the requested format " .Thats what it is saying when i try to get the audiotrack over with Virtual Dub version 1.4.7 and not Version 2.2 Betasorry my mistake.
greetz AndiHave fun with mpge,avi,svcd,vcd and so on.... -
Why not see if you can load it into TMPGEnc and see if you can save the audio that way. Or load it into Gold Wave as well?
Hello. -
likly it is a ac3 file and you will need to convert to a mpa file ..
extract the ac3 file with v-dub or some other app and then use besweet and convert the ac3 to mpa (mp2) .. mux that file with the video file you made earlier -- mux it with tmpgenc ..
I have no idea how much does this cost
By Artas1984 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Jan 2012, 13:47 -
I just had a really funny idea, but no idea how to do it, help =)
By NukeyDoo in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2009, 05:47 -
Idea for freebie
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 29th Jun 2009, 23:58 -
Any idea what this cartridge is?
By zevious in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2009, 13:33 -
Need an Idea for my research!
By zaf_81 in forum Off topicReplies: 10Last Post: 14th Apr 2008, 17:58
