I'm really confused with this. I've got Dune here with 29.97fps but my TV is not Multinorm so if I convert this to NTSC VCD I get only black/white.
I've used VirtualDub to save the video-stream with 25fps, stored the audio-stream as a wave, opened it with CoolEdit and slowed it down corresponding to the length of the video-strem, encoded it with tmpgenc and:
a) the video is not really smooth
b) the audio is NOT in sync (dunno why)
c) the audio is low-quality (some kind of chirping (I don't know the exact english expression for that, but I think it's because I've chosen low-quality in CoolEdit for the audio stretching (But even with low-quality the audio stretching took a looooong time).
Is there any reasonable method of conversion which doesn't take so much time, keeps video and audio in synch and with good audio and video quality?
thx
LZJ
i was just wonder why not converting your frame rate in TMPGEnc this would save some time and the quality is the same, also if your audio is off synch what you have to do is
to go TMPGEnc >file>TMPGE tools> simple multiplex
and after this is done go bbmpeg and mux video and audio
You are all set to go
good luck
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30 -
Would NTSC DivX play on PAL equipment?
By videoboy2008 in forum Newbie / General discussionsReplies: 4Last Post: 10th Apr 2008, 02:43 -
XVID/DIVX NTSC to PAL
By bilbonvidia in forum Video ConversionReplies: 14Last Post: 23rd Jan 2008, 23:13 -
Is DivX(Xvid) A Cure For NTSC/PAL?
By hech54 in forum Newbie / General discussionsReplies: 9Last Post: 6th Aug 2007, 12:13
