hi i will be doing most of my captures from my dish i think,and want good quality vcds with the possiblity maybe of doing svcd i was just wondering what the best capture card and or tv tuner if necessary would be. Perhaps a few ideas as im searching ebay for my bargain. Thanks alot for any help given in advance. Also what capture cards do avi do they all??
Results 1 to 12 of 12
You need to let us know what side of the Atlantic you are.
In USA I do not think there are any PCI cards that work
with Dishnetwork or DirectTV
In Europe they do have these cards, you need a smart card
or you only get a few free channels.
They let you rip the mpeg2 stream direct to the HD without re-encoding.
In USA:
You can always use Video Capture card, but with a
dish you do not get TV tuner function and would digitize a
analog (s-video) signal. -
im not in europe in north america i didnt know it was that hard what if i ran it through a vcr as the tuner?
ok im looking at dtv for some simpsons episodes and maybe music vids what is your opinion on the best card for this perpose? Would an Ati pci tv tuner card do i want decent enough quality .
No need for a VCR, you still have a "tuner" but you would have to change
the channel on the Satellite box.
The software on the PC can not do that for you.
it can with analog cable tv, if the card comes with Tuner that is.
Just use the S-video out on the Satillite box to Capture card
and a stereo audio cable.
Look in Sundays Newspaper for deals on them, Bestbuy or Compusa.
http://www.pinnaclesys.com/ProductPage.asp?Product_ID=6&Langue_ID=7 -
awesome but as being as unexperienced as myself do you have any advice on a card you have tried or heard of that is very good that i might try i need to buy one and dont know which to get i dont want to make the mistake of getting a piece of crap
What operating system are you using. I have been doing vcds on my imac using Eye-tv which uses RCA jacks and records into quick time. Toast then converts to vcd when you record to disk. Recording is in real time and about 6 minutes to do vcd. If you are using windows I don't know what you can use to record, I do know that most record in but the files are very big and take enourmous amounts of time to convert after they are captured. You would have to record to smaller files to cut conversion time.
One other option is to get a DV camcorder.
with S-video in and 1394 out.
Record to the miniDV tape and some cameras
actually have Analog to 1394 passthrough.
Probably will cost you around $400 but if you are in the
market for a Video Camera, why not.
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=8008351 -
hi i use my avi tv wonder ve to cap from dtv all the time with software provided with card. i cap to mpeg format as high bitrate xvcd. if im capping a movie i dont try to put more than 50 minutes per cd that way i can get high bitrate quality capture. i have 2 32" tvs and i cant really tell the difference between an avi cap encoded to mpeg and a movie capped to mpeg high bitrate. composite from card to sat reciever use line in for sound. im happy with the results. it is at vhs quality atleast. i mean come on if you want dvd quality buy the dvd. :P i use nero to burn turn off compliance. and my rca drd220 plays my xvcd's back at up to 2.5 M bit/ps which is pretty good quality. peace out.
All-In-Wonder® Radeon™ 8500 Video Card, AGP, 128MB DDR
$149 after mail-in rebates.
http://www.compusa.com/products/product_info.asp?product_code=293118#checkstore
Capture audio on PC from Dish Network
By doscai in forum Capturing and VCRReplies: 6Last Post: 25th Jan 2012, 23:08 -
ATSC tuner card that captures surround sound
By Theophilus in forum Capturing and VCRReplies: 3Last Post: 4th Jan 2011, 07:50 -
what's a good sound card to use for my captures?
By kukuo522 in forum Capturing and VCRReplies: 4Last Post: 3rd Aug 2008, 21:53 -
Which is Best DVB S PCI Card- Azurewave or Technotrend for dish ?
By sammy1 in forum DVB / IPTVReplies: 5Last Post: 11th Aug 2007, 11:27 -
Lip sync on video captures using VIVO card
By Confused Chimp in forum Newbie / General discussionsReplies: 1Last Post: 7th Jul 2007, 19:36
