ok my question is what r some good settings for good video capture
which codec should i use for the best quality in capturing?also is there any cd burning software that will burn dvd format...nero only has vcd & svcd
What capture card are you using? If you are burning CDs, you will have a hard time making them DVDs. You need a DVD burner. If you do decide to get one (they are too pricey for me), I suggest learning your way around TMPGEnc. It converts to DVD format as well.
Hello. -
the video capture codec depends on what card your using and what format ..
VV is more a DV based capture , but I guess it could work with other capture devices - havnt looked ..
Optimal Settings to export HD Video with 5.1 from Sony Vegas to a PCH A210
By BeeJayF in forum Newbie / General discussionsReplies: 0Last Post: 18th Mar 2012, 16:53 -
Best settings in Sony Vegas for capturing DV video
By fuzzblaster in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2010, 00:39 -
Capturing video through Vegas Movie Studio 9
By Michael Rodriguez in forum Capturing and VCRReplies: 1Last Post: 20th Mar 2010, 17:33 -
Capturing video... confused about some of the settings
By Cyber Akuma in forum Capturing and VCRReplies: 2Last Post: 20th Aug 2009, 12:05 -
Want to get home video pal VHS onto my pc HDD, recomended capture card?
By ha9981 in forum Capturing and VCRReplies: 6Last Post: 26th Mar 2009, 15:34
