Is anyone using an Xbox with MOD chip and running the Xbox Mediaplayer to play Divx?
If so what bios on Xbox MOD chip?
What ver of the Xbox Mediaplayer?
Does it look good?
Have you had any issues with any type of Divx files?
Do you copy them strait to the Xbox HD our do you burn them to a CDR-W?
If you burn them to CDR-W what CDR-W media work best for you?
Thanks in Advance.
If you have Qs about the media player check out the website.
www.xboxmediaplayer.de![]()
DO you work for Microsoft?
Panasonic DMR-ES45VS, keep those discs a burnin' -
Nope
I would like to try this to see if it works and to have a hardware Divx player.
So no one using the Xbox as a hardware Divx player???
Well I can get it working I will let you guys know how good/bad it is.
MediaPlayer 9 not playing MovieMaker wmv
By Punchcard in forum Video ConversionReplies: 3Last Post: 6th Dec 2010, 11:53 -
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
Convert DVD to ? for my mediaplayer
By daniel_c in forum Newbie / General discussionsReplies: 7Last Post: 29th Mar 2009, 14:19 -
RealMedia/MediaPlayer Classic
By JackPollack in forum Software PlayingReplies: 0Last Post: 18th Jan 2009, 19:36 -
Is there any FREE mediaplayer for use on symbian OS?
By bacardi/avt in forum Portable VideoReplies: 6Last Post: 30th Aug 2007, 11:41
