After I converted my avi to mpeg, the file size is 824MB. How can I split in into 2 files, and then burn them. Or through TMPEnc, how can I read on avi, and split it into 2 mpegs.
Even with over-burn I cannot burn the bin/cue file on 700 MB CDR
Are you sure.. a 700MB data CD will hold ~807MB of mpeg data ( mpde 2 ).
Look to the left under EDIT, as well as as long as it is under 80 minutes, and to VCD spec's you should be able to fit it. A VCD burn writes a VCD in Mode 2, so it doesn't rely solely on file size. See under AUTHOR for more info there
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
I think it go uptill 808MB, and then VCD Easy craps out. If this is not possible, how can I split the avi, or split the mpeg for VCD.
Spider,
It is greater than 80 minutes, I belive about 85 minutes.
Is it possible that TMPGEnc can make 2 mpeg, or can we specify max file size, anmd then start a new file. -
Ok, if you need to split the 824MB size file into 2 = size files, there is a program called VCDCut, It's very good, and it has a couple good other uses besides cutting up just MGG files. If you want my AIM name, here you go. I'll help u out. Spawn3745, and my E-mail is Spawn3745@yahoo.com. Just E-mail me, or just try to catch me online. I'm usually online all the time.
Well Peace out.
, AH......I was able to use TMPGEnc to make 2 seperate mpg.
And then used the VCD Easy to put it in 2 disks. I will look into VCDCut.
Thanks everyone.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
Having problems trying to split MPEG-4 file
By Xax in forum EditingReplies: 7Last Post: 4th Dec 2009, 17:27 -
Best way to split an MPEG file is to ???
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 7Last Post: 10th Mar 2009, 21:31 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 08:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 01:00
