I have TMPEnc plus. And everytime I start it, I get errors. The first one comes from when I try to edit the AVI file. It gives me this error:
Then when I finally get it to work, when I start the encoding, it gives me this:
Thanks..![]()
Could be bad frames.
Have you tried scanning the AVI in Virtualdub?"Today is only yesterdays tomorrow" -
enferno,
Could you post some details on the avi file in question such as the codecs involved. Also where the file originated (i.e. net download or something homemade) and some of the steps you've taken in your conversion process. Need more info to help.Warning! I'm baaaaaaaaack -
I don't use Virtual Dub..
I got the AVI file from the net. Its a movie, I want to burn it into a DVD-R. The steps I've taken are the ones provided from the VCDHelp Converting section. -
enferno,
I suggest you download a copy of VirtualDub and scan that file for junk frames. I've only seen those types of errors when there is a bad or corrupt frame and this is the quickest way to find out.Warning! I'm baaaaaaaaack -
You may need this version of Virtualdub:
(scroll down to the "mp3_freeze" version)
http://www.digital-digest.com/dvd/downloads/virtualdub.html"Today is only yesterdays tomorrow" -
Thanks wee haggis.
But I did what Kayfam said and so far its working. I did the FrameServe thing on the VCD Converting section and so far, its been great..
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 06:23 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
error in tmpenc
By php111 in forum Newbie / General discussionsReplies: 4Last Post: 4th Aug 2007, 07:56 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 16:44 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
