I burned (with Nero) a copy of the VCDHelp SVCD example (NTSC). That played with excellent quality on my APEX AD-1600.
If I burn a SVCD with Nero, it plays.
Anything coming out of Pinnacle Studio 8 does not work.
I have been working with Pinnacle support - but they clearly don't know much about SVCD yet.
Their SVCD's work on some other APEX models.
They contend that their SVCD's are standards compliant.
- they do not include a SEGMENT or EXT directory.
They will include them in future releases - but they intend to leave the EXT and SEGMENT empty.
They also say that the scandata.dat file is optional because:
"according to the SVCD 1.0 Spec dated May 1999, Page 19: The file "SCANDATA.DAT" is mandatory when the System Profile tag value = $01" in the INFO.SVD file, else the file is optional. The SVCDs Studio 8 creates set the system profile tag value = "$00" which means "SUPERVCD", so the file is optional according the spec."
The VCDHelp.com/svcd page could lead one to believe that EXT/scandata.dat and the SEGMENT folders are required.
I don't yet know if Pinnacle discs pass the Super Video CD verifier. But I intend to check that out - just found reference to the software a few minutes ago, in the forum.
I have asked APEX what is different in the AD-1500 and the AD-1600, they got back to me within an hour, but they told me to get lost.
I'm looking for a few things:
An answer to the SVCD tag question - is scandata.dat required under all circumstances?
Is the SEGMENT folder required?
What is the AD-1600 looking for that the AD-1500 ignored?
What could I do to get the Pinnacle discs within compliance?
The AD-1600 is brand-new, I'm considering sending it back while I still can, should I?
Any other ideas?
Thanks!
I guess I won't be checking the compatibility of the Pinnacle SVCD with the Philips verifyer - $500?
Input on any aspect of this problem would be appreciated.
PINNACLE STUDIO 11 - dvd no audio plays
By ancient in forum Authoring (DVD)Replies: 2Last Post: 10th Jan 2012, 09:07 -
Anything Sony DVD Architect won't do that Pinnacle Studio will?
By brassplyer in forum Authoring (DVD)Replies: 3Last Post: 17th Sep 2011, 01:38 -
Uncompressed AVI plays back in low quality with WMP12 & Pinnacle Studio 14
By textmagic in forum Software PlayingReplies: 2Last Post: 2nd Apr 2010, 05:25 -
PINNACLE STUDIO 11 vs. SONY VEGAS MOVIE STUDIO 8
By coody in forum Capturing and VCRReplies: 4Last Post: 26th Nov 2007, 19:53 -
TMPGenc won't allow bitrate to go below 1600??
By bebopdeluxe in forum Video ConversionReplies: 3Last Post: 10th Aug 2007, 19:49
