Me and da kitty are thinking of making a dolby surround sound intro logo.
Kitty says he can do video and I have got a great idea for the audio but kind find a suitible program.
Anybody got any ideas?
Baker
Results 1 to 13 of 13
im not sure this is usable as i know nothing about this software but i happened to find this today:
http://www.audiocutter.de/
AudioCutter Cinema
it is free right now for non comercial use and can do 2.0 Surround (compatible to Dolby-Surround®, Circle-Surround®),
4.0 Quadro (compatible to Q-Sound®, Environmental Audio®, Aureal 3D®),5.0 und 5.1 Surround (channel-compatible to dts®, Dolby AC-3®).
http://www.virtualworlds.de/Download/index.html (some other freeware there also)
but download also the real program here (legal) http://www.audiocutter.de/download.html -
I tried that proggie too - I even d/l the java and it still won't run.
Anyone have a short dolby surround clip?Panasonic DMR-ES45VS, keep those discs a burnin' -
Have a look at the Dolby tech documents. I think that they tell you generally how it is done...
L , R, C, S
L = L + 0.7*(C + S)
R = R + 0.7*(C - S)
From memory, the C and S audio is reduced by 3 dB and there is a high pass filter placed on them (?? kHz) and they are subjected to some form of Dolby NR (?? but I don't remember if the NR is on decoding or encoding as well).
An alternative is to use SoftEncode to actually create an AC3 or DTS audio (with 5.1 channels) and then use one of the rippers/downmixers to create your Dolby Surround audio.
Regards.Michael Tam
w: Morsels of Evidence -
Isn't besweet meant to encode ac3 audio? I know there is at least one or two other free ac3 encoders out there.
I have a AC3 Encoder, actually 2. One independent and the other part of scenartist. Basically they both work the same way, you make 6 mono wav files, one for left-front, center, right-front, the two back channels, and a LFE (low frequency effects) channel. It merges these files into a nice ac3 file which you can multiplex with lots of different file types. If you're planning to make an intro on a dvd you're going to have problems. First is getting the encoder (look on WinMX or get scenartist), which is not too hard if you get an standalone encoder. But to make a dvd that has 6 channels or in other words to author a dvd with Dolby Digital you'll have to find dvd authoring software that will let you do such. Most will take your nicely created ac3 file and downmix it to 2 stereo channels. I recomend scenartist although you'll have to spend lots of time reading and figuring out how to use it. I have used its ac3 encoder and authoring to make a complete rip of fight club with the original dolby digital track. I have also used it to take the dolby digital aurora movie which was coded and stereo and remixed it into dolby digital sound. For your use look into getting a program like I described. It is very easy to work with 6 independent wav files which then get encoded together. Good luck on you project. I would like to see a file cut when you're done. Email me if you'd like a copy of any ac3 work I've done.
Peace,
Mike G. -
Sheese..Has it been that long since DOS that people forget how they work? AudioCutter Cinema is probably a DOS based program. Open up a dos window and try running it. You'll probably get a list of necessary switches to be used with the program, or optionally, type in the EXE name with a '/?' after it (sans the '' marks ).
example:
audiocutter.exe /?Impossible to see the future is. The Dark Side clouds everything... -
Dos version works i understand (someone told me they are using it)..
do as DJRumpy says i guess -
Just keep in mind I have no idea what the actual filename if the EXE is. The above is just an example...
Demux a Dolby Surround 2.0 file into separate streams?
By Xoanon in forum AudioReplies: 27Last Post: 2nd Jul 2021, 08:21 -
ac-3 pro plugin and dolby surround
By ecc in forum AudioReplies: 1Last Post: 24th Dec 2009, 11:14 -
Editing Software that does not downmix Dolby 5.1 sound
By Persistence in forum AudioReplies: 2Last Post: 24th Aug 2009, 10:51 -
Converting WAV file to Dolby Digital® 5.1 Surround
By roma_turok in forum User guidesReplies: 18Last Post: 16th Nov 2008, 22:32 -
Dolby Digital Surround EX encoder
By grasswhopper in forum AudioReplies: 1Last Post: 17th Aug 2007, 23:49
