Hi,
I had a bin file only, made a cue sheet with VCDeasy (that changed the bin file to a bigger...) and burnt it with nero. Now on my cd I have 3 directories : EXT, MPG2 and SVCD. Problem : I cant read it, even the mpg file in MPG2, although I can read any mpg2 file I make from that film with VCDeasy...
Pls Help!!!!
Thnx
What did you mean by "made a CUE file with VCDEasy"?
The way to fix your problem is to regenerate the CUE/BIN image. The best way to do this is to use VCDXRIP on the BIN file and extract everything.
Then, immediately use VCDXBUILD on the created XML file to create another CUE/BIN image of the S/VCD.
You can either use VCDEasy as a GUI to these tools or try VCDImager Tools GUI. http://www.vcdimager.org/guides
Regards.Michael Tam
w: Morsels of Evidence
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
cue,bin converting to dvd?
By zziem in forum Newbie / General discussionsReplies: 5Last Post: 7th Aug 2007, 11:36 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29 -
How to merge 2 cue/bin to one DVD
By motleycool in forum Newbie / General discussionsReplies: 5Last Post: 7th Jun 2007, 22:26
