Iv'e just converted Ali.G.In.Da.House.DVDRip.DIVX.16-9.avi to XSVCD with TMPGEnc, and it looks and sounds just fine, but the sound comes a little bit before the video.
What did i do wrong?![]()
Is there a way to correct this without convert the video again? (ive got the audio as a seperate file that i extracted from the .avi).
Thanx for all help!
I reextracted the audio like the guide sad (resampled to 44.1 kHz) and then i Multiplexed the old converted video with the new audio (after i converted the wav to mp3 with Cdex). I multiplexed it with TMPEng, but it still dosn't work!
In the beginning of the movie it works fine, but in the end, the audio comes a bit before the video...
what to do? -
You, my friend, have what is called audio drift. If the audio file is longer or shorter in time than your video the fix is easy. If they are of the same duration, it is a little more difficult.
Next time, please be as specific as you can about your problem. It makes it so much more easier to troubleshoot.
Start hereHello.
Get Two AVI Video Framerate's to match
By Simmons in forum Video ConversionReplies: 4Last Post: 15th Aug 2011, 09:02 -
Audio does not match with the video
By c018279 in forum Blu-ray RippingReplies: 1Last Post: 31st Mar 2009, 04:10 -
Sound Miss Match on Premier Elements
By NP11073 in forum AudioReplies: 0Last Post: 18th Jan 2009, 02:27 -
Video and Audio does not match
By hzgg2 in forum Authoring (DVD)Replies: 1Last Post: 1st Aug 2008, 19:50 -
cant get audio to match video
By loa909 in forum Newbie / General discussionsReplies: 4Last Post: 31st Mar 2008, 06:35
