please help!!!
can anyone help me in fixing the sound problem i have once i have burned my dvd discs.the sound is very low yet when i play the discs on my computor but when i play them via my set top dvd player the sound is still lower than usual but when i put it through my surround sound system the sound is near perfect.
can anyone point me in the right direction.i,m using claddvd xp to download the movie,tmpeg to recode the movie and dvdit pe to burn my master discs.i then use nero to burn the rest of the discs of that same movie
any help with this would be greatly appreciated
del
how do i check the recording volume mate.which part of the precess would this be in please mate
del -
Go into your control panel and look under sound devices. With Windows ME, I do not know where to look exactly. But under sounds and audio devices is where I find it in XP.
Hello. -
question is this on just one dvd or all dvd.....because this is kind a strange you are ripping directly from the disc so if the source has a low volume then the rip audio will be the same..... I might be wrong .....
just my opinion...
HDMI sound problem
By visjds1 in forum ComputerReplies: 1Last Post: 28th Jan 2012, 13:25 -
no sound problem
By bountylord in forum Video ConversionReplies: 3Last Post: 26th Apr 2008, 18:37 -
problem with my HP sound
By arabian in forum ComputerReplies: 2Last Post: 27th Dec 2007, 03:51 -
Sound problem on PC
By greenpop in forum ComputerReplies: 2Last Post: 18th Oct 2007, 06:36 -
Problem with sound
By jarko in forum Newbie / General discussionsReplies: 6Last Post: 11th Aug 2007, 20:22
