MikeTheBike,
OK, for DVDx:
I see you used DVDx to encode Castaway, I have Castaway but am having dificulty with my final burn using nero 5.5.3.5
Can you explain your settings in detail, just too see that I have the EXACT same settings as your's, in mine?
Did you use VCD or SVCD or other?
Have you ben to any of my posts, search under "vhelp".
I am still trying to figure out why I am getting jitters and slow motion movements in my dvd player.
I have the AD-500, and now, am trying the AD-1500, and they are both producing the same jitters/slow motion thing.
And, yes, this is driving me crazy - as people are not letting me know if my clips are coming out ok... that is, if they even downloaded any of them. Here..., I'll give you a link to my Briefcase and select "RIP samples":
http://briefcase.yahoo.com/bc/a0z012yaya/lst?&.dir=/My+Documents&.src=bc&.view=l
If you have any trouble, please ask, nobody else seems to be reporting any trouble, so I'm assuming that everything is "A OK"!!!
Please if you have the time, check them out. I would really appreciate it. At first, I thought it was that "[ ] detect scene change" box, but I WAS WRONG!
JFYI: i'm only encoing small sections, about 30sec or so, because of the time it takes.
Anyway advise you can give me on DVDx and my jitters would be greatly appreciated!! Thank you! (sorry for the long message)
