I'm trying to add a denoise filter to my SVCD process in ffmpegX but when I encode I get the following line in my terminal window:
The process continues and finishes ok but how do I get this filter and others to work?Code:Sorry, no SIMD optimisations available.
Also is there any forum or web page that fully describes the operation of ffmpegX. I'm using it blind with the presets (which is great) but I'd like to experiment without burning a thousand CD's so if users have already found what the optimum setting are for a SVCD I'd like to know. Maybe we could set up a ffmpegX user site... I'd host it using movabletype.. Anyone interested.
Cheers
apt
Results 1 to 9 of 9
Hi, I'll really (really!) write a doc about ffmpegX. I'm just trying to make it stable enough (and I'm almost there..) to avoid to rewrite it every week.
Thanks for the swift response Major.... Any help regarding my filter problem?
Cheers
apt -
apt,
Hang in there, the user community that you are asking about is under way. I am about 1 month away from the release of a new MAC only VCD, SVCD and XVCD community.
There will be tools, discussions and answers for what we have been trying to do.
-S -
This is the output I get:
Code:INFO: [yuvdenoise] ======================================================== INFO: [yuvdenoise] Y4M2 Motion-Compensating-YCrCb-Denoiser INFO: [yuvdenoise] ======================================================== INFO: [yuvdenoise] Version: MjpegTools 1.7.0 INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr> INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler ## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt) INFO: [yuvdenoise] INFO: [yuvdenoise] Denoiser - Settings: INFO: [yuvdenoise] -------------------- INFO: [yuvdenoise] INFO: [yuvdenoise] Mode : Progressive frames INFO: [yuvdenoise] Deinterlacer : Off INFO: [yuvdenoise] Postprocessing : On INFO: [yuvdenoise] Frame border : x: 0 y: 0 w:480 h:576 INFO: [yuvdenoise] Search radius : 8 INFO: [yuvdenoise] Filter delay : 3 INFO: [yuvdenoise] Filter threshold : 5 INFO: [yuvdenoise] Pass 2 threshold : 4 INFO: [yuvdenoise] Y - contrast : 100 % INFO: [yuvdenoise] Cr/Cb - contrast : 100 % INFO: [yuvdenoise] Sharpen : 125 % INFO: [yuvdenoise] INFO: [yuvdenoise] Sorry, no SIMD optimisations available. ++ WARN: [mpeg2enc] Generating dummy SVCD scan-data offsets to be filled in by "vcdimager" ++ WARN: [mpeg2enc] If you're not using vcdimager you may wish to turn this off using -d
Hope this help.
apt -
The SIMD (Single Instruction Multiple Data) message doesn't mean that the filter is not being applied, but just that it is not accelerated. If you're sure the filter is not being applied, then we should be able to reproduce your observations in order to help, in that case please tell more about your findings.
Ahh Sorry for the trouble... I didnt think that the filter had been applied because:
a) That message.
and
b) There was no obvious difference after having the filter applied.
Thanks again and if you need any help with the Mac VCD community give me a shout, I've a lot of time on my hands at the moment. I'm a graphic designer and can do php, cgi, web stuff.
apt -
Originally Posted by apt
bd rebuilder encoding options question
By kronick in forum Blu-ray RippingReplies: 0Last Post: 3rd Jul 2011, 11:21 -
No encoding options in XMedia Recode
By thezanny in forum Video ConversionReplies: 2Last Post: 26th Apr 2011, 07:02 -
encoding .m2ts with Megui. What's the best options?
By badreligionhead in forum Video ConversionReplies: 4Last Post: 23rd Sep 2009, 15:24 -
AutoGK encoding options
By MyBigToe in forum DVD RippingReplies: 2Last Post: 3rd Mar 2008, 11:47 -
FFMpegX 0.0.9w problems converting / missing options?
By macuser1960 in forum ffmpegX general discussionReplies: 6Last Post: 4th Jan 2008, 16:26
