Damm Disn... they make it hard on us. It has different angles. I tried ripping angle 1 and usin ifo edit to get everything together but the movie is just wacked. I need help. I just want the movie and english. It can fit on a dvd-r but I'm not used to multiple angle dvds.Help!!!!
I struck problem on Phantom Menace, Checked out the ifo file (using ifoedit version 0.932) found which Vob-ids the extra angles were using, in my case 2,3,4. When it asked for which vob-ids to include I left out 2,3,4. I think I also ticked the 'remove-angle' box too.
"I struck problem on Phantom Menace, Checked out the ifo file (using ifoedit version 0.932) found which Vob-ids the extra angles were using, in my case 2,3,4. When it asked for which vob-ids to include I left out 2,3,4"
May I ask exactly how (in IfoEdit) you discovered the extra angles were in vob's 2,3,4? I'm trying to rip Phantom Menace to 1 DVD-R - but have struck probs with this multi-angle issue you've raised as well trying to get it to <4.7Gb. By stripping menus, angles etc, I get it down to just over 5Gb (unless all else fails, am very loathe to cut down on the video quality as described in various guides). Any guidance? -
If you used a ripper that does IFO pasing like DVD Decrypter 3, and enabled stream editing, it would create VOB's with only one angle, the main title, and audio track of your choice. Re-author and burn away
Ripping with angles
By Dozza in forum DVD RippingReplies: 4Last Post: 18th Apr 2019, 14:54 -
adjust angles
By ecos in forum EditingReplies: 2Last Post: 31st Jan 2012, 17:00 -
prediction: "Bulldozer" will be a beast
By deadrats in forum ComputerReplies: 6Last Post: 3rd Oct 2011, 06:37 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Angles using freeware - is it possible?
By Qun Mang in forum Authoring (DVD)Replies: 10Last Post: 5th Sep 2007, 08:27
