    Aug 2001
    Hartford, CT
    I downloaded a movie in your basic bin and cue file format. I used isobuster to extract the .dat file out of cd1 and it worked fine. I tried the same with cd2 and the dat file shows the first frame and then stops. I'm using gdivx player. I even tried to burn cd2 with cdrwin, but the dat file did the same thing. i even tried to use DAEMON software as a virtual cdrom with no avail. Can someone please help?
    Aug 2001
    Hartford, CT
    I also tried to play the file with vcd cutter and Windows media player and they worked....huh? Why would it not work with DIVX. Please help me!!!!!!!!
  3. try running the file thru VCDGear.
    http://www.vcdgear.org/download.html
    It might just solve your problem.
